Thanks, Jay
My car seems to have poor boost response, though. The lag is noticeable. I need to spend some time with it this spring and work out a few tuning issues. I installed a B to B FAST and need to tune it. I also have an oil leak at the girdle I need to get to. I'll pull the engine and check a few things out while I'm at it. It does make just under 600hp at 19.5 lbs. of boost, though. (127+mph in a 3875 lb. car.) It really wants to pull through 7000 RPM. Lots of exhaust flow with two turbine housings, eh?
I have a TON of overtime facing me (haven't had a day off yet this year) and a "few" engines/chassis to build for other folks that take priority. (not to mention family)
One change I would make to my headers is to reduce the size of the collectors (turbo inlets) down to 2" instead of 2.25". 2.25" is way over kill unless you are making more than 800hp. There is lots of room to mount the turbos in tandem like I did, and keep all the AC, PS, ALT. My system is completely bolt-on and I only had to drill two hole in the core support to mount the intercoolers. (two stockers welded together) For the right price, my system is for sale. PM if anyine is interested.
