FlintBuick4Life
- Aug 26, 2009
I am trying to figure-out what the idle speed is on my engine(NA 3.8 4bbl Edelbrock carb) I have been looking through my Haynes book and it tells you how to adjust the idle speed, but it doesn't tell you what RPM to set it to I don`t want to set it to high, but when I takeoff hard(brake+gas) it will sputter and it cutoff once.
Also, I still can`t keep oil pressure cold starts at 60psi, drops as the temp raises and when warm, I have maybe 5psi at idle I have replaced the oil pump many times and still no luck. I have tried different pressure springs. Any ideas
