Guys/Craig
I have a FAST SFI setup w/ICC. I have been trying to get the individual cylinder control (Timing Retard) to work since we installed it. The fuel portion appears to work ok. The problem is I can never find any retard on any cylinders. Following the instructions (RTFM) I took 10 degrees out of number one reved the motor to 3500RPM on the chassis dyno and then looked on #1 for a 10 degree retard off of a base timing of 34 degrees. No such luck. We than checked the other 7 cylinders and never did find the retarded timing.
I am having driveability issues with a Mid RPM Miss which I posted as well and I am wondering if the two could be tied together. I have the following setup for Crank/CAM Sync. I can't use a crank trigger do to room issue in my C4 corvette.
Crank Trigger: MSD Distributor Reluctor
Cam SYNC: MSD Shaft Pickup/EFI Distributor
The distributor has been checked and phased and the crank reference angle is set to around 53 degrees. Base timing is 34 degrees or so.
No matter what we do we can't find the 10 degree retard. I am beginning to wonder if I have a problem with the ECM. But than again at WOT the little TT Motor makes 1KHP so it must be doing something correct!
Thanks,
Doug
P.S. I have a FAST harness/Factory ECM Completely Removed!
Thanks,
Doug
