BMF_Racing
ONE B.M.F.
- Apr 26, 2006
Well to start off The motor is a unopened 109 with a set of club valve springs. The other mods that are not stock and matter are:
6776 dbb, ESP FMIC, 60# inj, Alky Injec 490ml nozzel, MAFT Pro w/LM-1, 62mm TB, 62mm Hemco, 3" THDP, Red Arm. pump/hot wired, e-cutout at end of DP (open). --- Everything else is stock.
Well after doing alittle tuning on the car on the way to the dyno (Wicked Women of the 1/4 mile Dyno Day @Cincy Speed) this morning, we came up with the following conservitive tune (still stock trans/convertor).
Boost : 20 psi
Timing : 21.5 degrees
Fuel : 110 race w/lots of akly
WB AFR : 11.5 to 11.7
Here's Lacey's graph of the 20 psi run.
So are these hp/tq #'s in-line for the mods listed, for those of you that have seen the 6776 on the dyno?
Thanks,
Brad
Boost : 20 psi
Thanks,
Brad
