ATR exhaust 3 inch single with test pipe no catIf you still have a catalytic converter on the car, those have been known culprits to the car not breathing properly. Straight pipe it or put on a test pipe in it's place. The difference is night and day if you still are running one, especially if it is the original one.
At only 15 PSI of boost, I'd be thinking it'd level out in high gear and won't pick up much.
With 18deg timing and 17# and stock ic I ran 11.7 on 93 oct.
And I don't see the comedy at all and the BS flag, really. Need Boost went 11.7 on 93 also. Believe it or not...I have no damned reason the blow smoke up anyones butt.I don't know whether to raise the BS flag or not. I'm to busy trying to stop laughing.
True that, he's looking for advice not "comments" that don't relate to the thread.OP isn't looking for a pissing contest.
But you also said with only 17# of boost. Also with low timing and straight 93.And I don't see the comedy at all and the BS flag, really. Need Boost went 11.7 on 93 also. Believe it or not...I have no damned reason the blow smoke up anyones butt.
I understand night shift..... the reason I asked about the gap is because the turbo can blow out the spark at higher boost levels. The fix is to tighten the gap up to .028 and then see what it does. Keep us posted.I bought the car in April. Has great upgrades but the guy didn't tune it properly. Just trying to unfuck everything that was done incorrectly. I'm getting a Razors Alky kit this winter. Will upgrade timing chain and new pulleys. I'll verify timing and run a FP gauge to the windshield to verify everything in the spring. Little by little. Thanks for all of the suggestions guys. I appreciate it. Sorry I responded so late, I work midnights as a mechanic for JetBlue. Wrenching on planes and the. Get home to tinker with the Buick. Never ends
