BetMinesFaster
Turbo LSX Trader
- Aug 7, 2007
Hey guys, got a dumb question, what size throttle bodies are you bigger inch stage guys running? Im looking at a new project and im trying to collect some info, Thanks:biggrin: Ryan
300 feet per second flow through the throttle body should be the max rate. If you use that to calculate your TB size, you may find that you need bigger than you think. I went 100mm. One of the main reasons for that decision was the way air enters our manifolds. Too bad we couldn't have the air enter straight down. With the way air enters the plenum I wanted to slow the speed down to control turbulence that may occur feeding the two front cylinders.
70mm, 162.5mph, 26#, pt88, 3" pipes, ATR 4 bolts.
Don,Why cant you just make a manifold with an upward facing t-body?. Too bad we couldn't have the air enter straight down. With the way air enters the plenum I wanted to slow the speed down to control turbulence that may occur feeding the two front cylinders.
We have dual 75s on the car we're building.
It would require an elbow in the intercooler piping.
I wonder if there are some old open plenum stock style head intakes around that can be modified
