It seems like people are torn between the two. Which roller do you recommend? I was thinking the original style because of the use of the tensioner, the plastic gear not throwing off the knock sensor etc.
This COMP Cams® Hi-Tech™ chain set is designed to work with all hydraulic roller and flat tappet cams. Ideal for all street performance and race applications.
Cast Iron camshaft gear and induction hardened billet steel crank sprocket • Feature 3 keyway crank sprocket for 4-degree incremental adjustability, 4-degree maximum advance/retard • Pre-stretched, heat-treated double roller chain with heavy-duty large pin design • Dynamically balanced and quality checked for run-out tolerances
