Scott89TTA
- Jul 12, 2005
A bunch of us went to Mason Dixon Dragway today for some Test & Tune.
Great day at the track...weather was awesome
Made 3 passes all @ 24psi, launched off the trans brake, 18psi in the DR's, "0" knock, O2's 790-800 every pass.
1st pass: about a 6-7 psi launch...started out good then I didn't know where the finish line was so I let out real early (1st time running at Mason Dixon) :redface:
60ft 1.768
330 4.923
1/8 7.595
mph 91.00
1000 9.931
1/4 12.327
mph 82.74 :redface:
2nd pass: decided to try a 8-9 psi launch off the trans brake ended up ~10 psi...the car hooked nice!!! I did bump the shifter into OD and it shifted into OD near the end...I need a better shifter or a shift gate for sure.
60ft 1.571
330 4.658
1/8 7.306
mph 90.81
1000 9.594
1/4 11.556
mph 116.22
Oh and my 1st 11 sec pass ever :biggrin:
3rd pass: stuck with the 10-11 psi launch...got a little loose and out of the grove got back in and still nice. It was getting cold...probably should have dropped the tire pressure a little...I did shift it right this time so still real happy!!!
60ft 1.578
330 4.690
1/8 7.354
mph 90.38
1000 9.652
1/4 11.631
mph 113.78
Thanks a bunch to Trent (ttafan) and Charlie for the coaching
Doug (1of1547) and Chris (Savagite) both had a good day with new best runs for each as well...Trent's TTA looked AWESOME as usual especialy with his new wheels & tires
-Scott
60ft 1.768
330 4.923
1/8 7.595
mph 91.00
1000 9.931
1/4 12.327
mph 82.74 :redface:
60ft 1.571
330 4.658
1/8 7.306
mph 90.81
1000 9.594
1/4 11.556
mph 116.22
60ft 1.578
330 4.690
1/8 7.354
mph 90.38
1000 9.652
1/4 11.631
mph 113.78
-Scott
