Start the car cold. Reading with Direct Scan. IAC is about 60 until car goes into closed loop. Then the IAC counts start to drop until they each 00. They jump up if I throttle the car quickly. If I rev slowly, they stay at 00. I have tried to adjust the screw on the throttle body to see if the counts would come up, but they dont. Also, when I drive the car, it cuts out when not under a load. Could this have anything to do with the IAC. Everything else on the Direct Scan seems to be normal.
