so did u sell both sets?
Yes.
Bob,
I got my dogbones, and spider out of a 3.8 FWD 1986 Olsmobile
at Pull a Part.
My lifters cam out of a Pontiac Grand Am 3.1 V-6 that already had
the intake removed.
All my stuff cost me $40.00
What application year/years on the lifters?
Are these the lifters to use ?
Sealed Power Lifter
Part No: HT-2270
Is this the correct application? "1996 Pontiac Grand Am SE 3.1L 189CI V6 FI VIN: M"
Would any of the shelf Turbo Buick Roller cam work with this set up?
Yes. GM part# for lifters 17120070
OTS Roller cams have worked thus far - need to be aware of overall lift though.
HTH-
Frank, when are we meeting up for Barona, or Qualcomm? ; - ) It's been a few years now...
you should have known that my dumb ass (LOL)was going to ask,
Whats the Max lift/size cam that can safely work with this lifter setup?
thanks for your help and replies guys.
David
David
87Buickracer, have you had a chance to try this combo at the track or have you dynoed it yet, if not got a guestamet of the rwhp?
I also have special request. If you took pics of the roller setup and your build, could you email me the pics? I've followed this thread and it has gotten so long and polluted with side stuff that I'ld just like to see what your setup is. Oh, one more question, what method did you use to retain the billet cam?
I have a few more things to do before going to the track.This car has alot of power and safety is my main concern now..I just ordered rear control arms this week..currently getting new brake parts and will order drive shaft loop next week..I dont want to hit the track and not be able to stop if you know what I mean..All the info you need on my build up is in the beginning of the thread..my roller cam is the weber billet cam with the nose gear you assemble with the cam eccentric and key way...the fwd parts are the roller lifters ,dog bones and retainer..I run comp cam push rods and beehive springs recommended for cam..you will need to use a adjustable pushrod checker to get your specific pushrod length..I backed the boost down to 17-18lbs and it still smokes the tires at 5lbs boost.feels like it should run a hi 10 low 11 sec run at this boost level with a good 60ft time..I also changed alky nozzles to one m10 and one m15 for this low boost level..once I get to the track I will post up some numbers..will be after new years,so that will give me time to finish with brakes,control arms and drive shaft loop..If you need anymore info just let me know...hth
This is a great thread as soon as I find a 109 block I'm going to start a new build I know this has been asked but can you use the FWD 86-87 heads arn't those the same heads that came on the TA I like
Are the dogbones alumiunum or steel?
