Street can be interpreted many ways, but if you want to push that turbo, without alky the 307 on factory lines will not net you mid 10's on a full weight GN, even with the 60lbs. IMO you will need alky and an upgraded fuel line set up to run one pump comfortably on a BB67 into the mid 10's ( hot wired of course ).
If you are talking true gas street set up ( 18psi ) than you are ok.
Razor pumps in a lot of alky, I believe he said around 20% of his fueling was alky so take that into consideration on his mid 10 runs.
