These guys on the TV series have a lot of expertise. There is quite a bit of technology layering there, like electronic throttle control, which has the ability to disable the injectors. I worked for Ford Powertrain for 4 years doing fuel subsystem driver software. Working with Ford's first domestic ETC program, the 2003.75 Lincoln LS, at some point during the program the ETC was enabled and during a bench test I wasn't able to control the injectors. I was able to, however, tap off the output of the TPU to monitor the signal that would turn the injectors on and off.HUH??? I see these kinda swaps on TV series shows all day..... Old cars new EFI engines...
If you are planning on pulling an EcoBoost engine and doing this yourself, all the best to you. I haven't checked Livernois MotorSport to see what that offer, I live about 20 minutes from their shop. Perhaps they have a engine with a controller ready to go, I'm sure it's not cheap. Then you have the integration or mating of an engine to a transmission.
I have thought about this very thing and I have also considered GM's 3.6L v6 LGX and twin turbo 3.0L v6(LGW). I have also considered GM 2.0L Ecotec, the one out of the ATS(which is sold as a crate motor with ECM and harness), but I don't have the knowledge, nor the time or money to invest in such an endeavor.
Good luck.
EDIT:
The 3.6L and TT 3.0L engines will not be available until the 2016MY of the Gen 6 of the Cadillac CTS.
