fast400 said:Anyone have this issue? When putting the timing cover on with the roller button installed, it touches the cover before being flush with the block???!
Recheck the fit of the button to the camshaft, and make sure the button is fully in place. Make sure there is no casting flash on the cover, as others have said, that could be causing the interference. Keep in mind that shimming requirements will differ from cover to cover, engine to engine, cam to cam, etc. Most importantly, verify that the cam is properly machined. There are improperly machined cams out there that have extra thick thrust surfaces, that will push the cam forward, causing this lack of clearance, as well as lobe to adjacent lifter contact if not corrected. This can ruin your engine if present and undetected!! I, and others, have posted of this in previous posts. In my case, the thrust surface of the cam was .040 too thick. I had my local shop cut it down to the specs found on my old oem cam, as well as a flat tappet Edelbrock I had here. They were identical, but the Comp was thicker by the .040 I mentioned.Anyone have this issue? When putting the timing cover on with the roller button installed, it touches the cover before being flush with the block???!
If the Comp Cams button is like the Meling cam button and you are not using the spring, you can remove the retainer and take out one of the shims.Anyone have this issue? When putting the timing cover on with the roller button installed, it touches the cover before being flush with the block???!
We're talking about a roller button. Now some clerification is needed. Is the OP talking about a roller cam or a flat tappet cam???? Flat tapped cam uses a roller button on a spring.
We use a roller button on a spring for stock-type cams, flat tappet or roller.
After maybe a hundred or so ductile roller cam installations, so far no issues, and a LOT simpler/easier than the shim type with no spring.
Dave, I'm fairly sure the OP was about a roller button run on a cast roller cam (not a billet roller with the oddfire nose).
I ran into the opposite problem with a roller button. I had too much cam endplay and shims were NOT going to correct the problem. The front cover was re-machined in the cam thrust area to eliminate grooves left by previous use. I took the button apart by removing the tiny C clip and made a new thicker body for the button out of 300M steel.
If the previous suggestions don't pan out, disassemble the button and have somebody with a lathe, face off the area that touches the cover. I'll be glad to do the machine work if you want to send me the button. I'll need a dimension that will work for you. PM me if you need my help.
Nick, do you sell those?
RL
