I'm looking to sell some "un-molested" stock parts off of an 87 T. The car was very well cared for since new!!! I wanted you local guys to get the first shot at these parts. I don't want to have to ship anything, so pick-up only or I might meet someone halfway if they live in the Chicagoland area.
Everything here is priced to sell!!!!!
Complete factory long block. 80,000 original one owner miles. The car was sold to me from the original owner (the women was 70 years old when she sold it to me). Engine never saw over 4,000 rpm (until I bought it). I've put 1,500 miles on it since. I pulled the motor and disassembled it to have it rebuilt, then I put it on hold for my stage II build. The block and crank were checked out. Nothing wrong. The block was hot tanked. It will clean up at 20 over. I don't remember if the crank needed to be cut or not. Nothing was hurt! (Everything that was bolted to the engine is included except the drivers header, which I sold). All parts are clean! The intake and valve covers are freshly powder coated silver/aluminum color.
$900
Extra Coil Pack (known good) $25
Extra Coil Bracket $30
Stock Turbo and Heat Shield. Heat shield is freshly powder coated silver/aluminum. Something was wrong with the turbo at the dealership in 87 before it sold, so the dealership installed a new GM turbo with adjustable wastegate (the rebuild tag on the turbo says "rebuilt unit" on it)
$150
Extra Turbo Heat Shield $35
Extra Adjustable Wastegate $15
Extra Turbo Inlet Bell $15
Stock Intercooler with Shroud and brackets. Items are in Excellent shape. I cleaned the intercooler out and had it painted. It still has the original tag on it. No fins are broken or bent.
$150
Stock Up Pipe $30
AC Compressor. It operated flawlessly when it was on the car.
$75
AC Lines. Very good condition.
$70
Complete Power Master Brake Unit. Very good condition. Operated flawlessly.
$175
Power Steering Pump $60
Power Steering Reservoir $20
Power Steering Box $30
Steering Linkage $20
Stock Radiator. I had it re-cored and cleaned out by Cool Heat. Great condition.
$100
Windshield Wiper Motor. Worked flawlessly. Clean.
$30
Wiper Arms $30
Wiper Actuator Rods $10
Stock Air Filter Canister $40
Stock MAF Sensor with screen (Works Great) $35
Extra MAF Sensor without screen (known good) $30
Stock Flexible Air Intake Hose (Decent Shape) $30
Gray Shifter Handle. This is probably the nicest shifter handle I've ever seen go up for sale, that isn't new. I don't remember from who or when I bought it, but I found while going through some extra parts today. There are no flaws on this, period.
$50
Stock Front and Rear Sway Bars $25 each
Stock Drive Shaft $45
Stock Rear Upper Control Arms
Stock Rear Lower Control Arms
2 1/2 inch dual Torque Tech aluminized exhaust with Dynomax mufflers. Sounds Great. Not too loud. Only on the car for about 500 miles. No dents or big scratches. Good condition. Includes test pipe.
$200
ATR Timing Doctor with manual (good condition) $25
I have some used emblems off of my 87 T before it was painted. They are all in good shape, but not like new. Let me know if your interested in one.
I also have some GM service manuals and a Buick Sales Catalog for 1987
NEW PARTS Listed Below......
New Stock Appearing Ignition Wires 8mm (can't remember who made them) $45
New Billet Aluminum Thermostat Housing with seal $25
New Billet Aluminum Thermostat Housing Hold Down Clip $10
New 160 deg. Thermostat $15
New Grommets for Valve Cover and PCV Valve $10
New GM "3.8 Turbo SFI Hood Emblems" (3) $60 each
New GM "Regal" Emblems (2) $70 each
