Originally posted by 87buick3825
No
Originally posted by MSDGN
Crankshaft Endplay...40 to 70 thousands... ...I'm sure that was a typeo...if you have that much play you have much bigger problems...endplay should be around .004-.010...
Originally posted by Slowhawk
Well,I let the car sit for 8 hours and started it again.It stuttered once and held idle fine.No engine knock while idling.So now I'm convinced it was the camshaft position sensor.There could be a posibility it moved but I will replace it anyway's.
Originally posted by darkred87T
My car has the same problem when starting cold. It stumbles like it's randomly missing cylinders until it warms up. Also, a loud tapping comming from what seems to be the cam sensor. However, I have to agree with 87buick3825. I'm not convinced the cam sensor has much to do with how well the car runs. www.gnttype.org gives a good description on the function of the cam sensor.
Originally posted by turbojimmy
Slowhawk, did you replace your cam sensor yet? I replaced mine yesterday with a good used one and it cleared up my knocking noise, however, the car still stumbles when it warms up. Just curious because it sounds like we had the same problem. BTW, I'm Darkred87T, just using my brother's ID.
