Dreamcar86
- Apr 13, 2006
Normally I figure this stuff out but this one has me stumped. This is a no spark situation however every so many cranks it will spark then nothing again. Has anyone had this no spark then spark then back to no spark? Is there a ground wire I am missing or wiring harness problem?
Here is what I have done so far:
- checked all fuses
- checked battery voltage while cranking
- swapped out my coil and ignition module with a new one I had on the shelf
- swapped out my crank sensor with one I had sitting on the shelf.
- checked fuel pressure
- visually inspected grounds
- checked all connections and pins
What next?
- checked all fuses
What next?
