Stan's Customs
- Jul 23, 2008
Wow 625 pages to search on transmissions alone...2 hours and I haven't made a final decision.
I've been building a '61 corvette for several years and am using a Buick Grand National 2004r..
(yep the real deal too) I've had the pan off and checked the valve body , governor and servo. It all matches the info I have that indicates it is a GN trans.
The car weighs 3000 lbs., the engine is a new carbureted GMPP ZZ4 , (350Cubic inches, 355 hp., 405 lbs. torque according to GM), peak torque around 5500 rpm, tires are 215/70/15 Michelins...rear is a Dana 44 with 3:33 gears....in a Corvette Correction C4 custom chassis.
The car is to be a "show driver".. parades, occasional romp around the Sonic and down the drag on Saturday night ..and perhaps some short 200/300 mile rod runs in Texas heat. (car has AC, electric windows, Be Kool radiator, Spal fan, etc.)
In short.. all around drivability is paramount....and next, just a FUN driving experience, along with absolutely the best that can be done for reliability.
You guys have the most knowledge regarding these transmissions of anywhere on the internet....so I thought I would see if I could get some opinions regarding how you would set up the transmission for this car. I may not need much of a stall converter for this kind of driving? I can't make up my mind regarding a lockup or non lockup converter? ..or the easiest way to wire it, if a lockup is the answer?.
One of our local transmission guys thinks a lockup 12" converter with the lowest stall available would best...with a simple switch to lock it up in 4th. Keep it simple is his thoughts...and I can't say that I disagree, but all the reading I've done here has me doubting what to do ....there's a lot of ways to skin this cat.
I'd sure appreciate some concise recommendations for this car's 2004R, if anyone would care offer their opinion on stall, converter of choice (lock up, non lock up , and size 12", 10")...along with a converter source if you don't mind.
Of course any other comments you would like to make are welcome as well.
Thanks and best regards.. Stan M.
