If your stock turbo isnt shot why not put an adjustable wastegate actuator on your stock turbo? Simple and effective. But when you start increasing the boost you put a bigger demand on the fuel system. If it was my car with
your goals I would put a Fuel pump and hotwire kit on it, Adjustable fuel pressure regulator, Turbotweak chip, Adjustable wastegate, and maybe a set of 42.5-60lb injectors (these injectors will have enough room for you to upgrade the turbo later), and a K&N air filter with a good solid MAF pipe and a SCANTOOL. For under $1300 bucks. A new turbo is going to be $600+, and you still need to upgrade the fuel system after you put it on. If you would like to talk about possible options for your goals you can give us a call at
GBodyParts.com Online. We wont sell you anything you dont need. Feel free to call with any questions.
