Was driving the car on the 22 freeway yesterday (about 5 miles from home) cruising about 70 mph all of a sudden the car started to pop and miss and stumble
Temp was fine, oil pressure was fine, fuel level was fine, nothing obvious I could see so I dropped it down a gear to keep the rpms up and proceeded to limp it along to get as close to home as possible incase it died on me
I managed to do the put it in neutral / put it in drive / keep the rpms up dance all the way home and got the car back into my driveway (still popping & missing)
Lin heard me pull into the driveway and came out to see what was going on so I had her grab the ramps so I could elevate the front end and as soon as I took my foot off the gas, the rpms dropped and it died
No leaks, no obvious grounded wires, no parts hanging
Pulled the plugs (all black & sooty - rich), pulled the cam sensor cap to check for a loose screw or broken tab
Checked the ESC module connection, checked the plug wires, checked the coil pack & ignition module, checked the fuel injector harness connection, checked the crank sensor, fuel pressure gauge on rail was 42 psi (line on)
I cleaned, re-gapped and re-installed the plugs
Started it up and it went back to the sputter & pop routine
I've never changed out the coil or ignition module since i've had the car (if it ain't broke don't fix it) and based upon how suddenly the symptoms cam on (while cruising smoothly) it seems like an electrical issue to me
Since I drive the car daily my problems are not from the car sitting for weeks or months at a time, so I will look more into it this afternoon when I get back from helping a family friend (who is moving) move some heavy furniture.
At the birthday party I went to last night, when this friend heard that my car was acting up and that I would not be able to go on todays cruise, he decided to move up the time for me to help him move from 3:00 this afternoon until noon
So not only do I not get to work on my car until late this afternoon, but I get to miss out on another GN cruise, and hanging with the Homies down at Mr. Ralphs Den of Sin & Family Pizzaria
Enjoy the day everyone
I'll catch everyone next time
