have code 24 is the vehicle speed sensor I pulled dash the green sensor not there also look under hood followed the Speedo cable still nothing does anyone know on GNX where it is ? Thx
if you want to remove it and it has a mechanical speedometer you'll have to disconnect that in the engine compartment first. I'd suggest removing the dashboard section that surrounds the instrument panel as well so you can see behind it.
