Hello,
I'm having a voltage issue, and I'm trying to diagnose the. When I run the car, the voltage meter stays around 10 volts, until I rev the engine then it goes to maybe 11 or 12, however the engine can't get to high of RPMs as the car then sputters (perhaps because its not getting enough power to plugs?). So far I have replaced the battery, replaced the positive and negative cables, and took the alternator off and had it tested at an autozone.
I'm not sure if this is related but my scan master also no longer works (perhaps also because the voltage is so low it can't get a signal?)
One thing that I felt was also odd was that when I disconnected the hotwire kit to the fuel pump and ran the pump off the normal wires, it smoothed out the idle, when I disconnected the pump completely the car ran much better...
If anyone has any advice as where to look next I would greatly appreciate...also the voltage light in the car does flicker on and off spuratically.
