I speak from ACTUAL experience using rebuilt MAF's. What are you speaking from? Was your .2 second / 2mph (20 hp) gain a documented improvement or a seat of the pants dyno gain? And your slanderous comments about the auto parts store MAF's couldn't be any further from the truth. Yes there are some cheap rebuilds out there but to label them ALL crap? Do you think Kirban has some special Elve's in his basement making these things? :biggrin:
Yes, documented improvements. Actually slightly better than .2 and 2 mph but I rounded down. This was moving from a good "original" stock maf, up to a 3" LT1 and then from there up to a 3.5" LS1 MAF and the assosciated translator + hardware.
Sorry, but I disagree. Auto parts stores MAF in fact are very seldom correctly calibrated (it's pretty much been proven time and time again). All one has to do is read the associated posts. In fact many are being sold for the GN aren't even a turbo calibration but rather the N/A calibration MAF's. How many pictures do you see here and various other places throughout the internet where some poor unsuspecting T/R owner in now sporting the "hour glass" shaped MAF? I see it a lot.
I don't know anything about Kirban's stuff. Haven't used them and wasn't speaking of them. I've moved beyond the stock maf's anyway.
Were these documented tests on the same track day & run at the same boost level? .2 from 2 sets of larger MAF's & the hardware? IMPRESSIVE!! It seems some have seen a 2 lbs. boost increase with these sensors, could that be the great source of the power increase? I have also seen poor quality rebuilt stock MAF's & the wrong one's installed but i've also seen plenty of poor running cars with translator issues, rattling MAF pipes & the other trinket's needed to make this stuff work. With plenty of cars running in the 9's & 10's with the stock MAF's is it fair to label all stock MAF's as "crap"? I guess if you like the NOPI tuner look under your hood you might as well add a 6' aluminum wing to your trunk lid, i'm sure you will gain .2 on a road course somewhere.
Been thinking about getting rid of the old stocker. What does it cost to get set up with a translator + 3.5" maf? Can you still run a Turbo Tweak alky chip ? Will the fuel and timing parameters still function? If I can gain .2 sec or 2mph that will be money well spent. Have a couple friends BigAir and ROC 87 that said they like theirs. Hopefully I can get set up for close to 2 bills. Who has the best prices Full Throttle?
Flyin GN where you gettin it for 260?
Anyone know the failure rate between stock MAF's, aftermarket MAF's, and wideband O2's?
And which if failed could damage the motor due to causing an improper tune?
I would like to know what happens if the wideband goes funky or out completely?
