Not at the track. I sold it before I got it there.Did you do a full pass at the track at 35lbs?
ks
So KevinS and and WE4Mateo, what Afr and timing are you guys running with those boost levels?
Eric at TT programmed the chip for 35psi and 100% meth so I’m not sure on the timing he used.
I was chasing issues with the fuel psi not rising in correlation with the boost and once I figured out the issue winter hit and the car went into storage then sold shortly afterwards. I know the AF numbers I saw on PL didn’t concern me too much and felt it was still safe.
ks
What do you think? I told Eric everything the car had and want I wanted to do so he programmed the chip. What timing he had in the chip didn't make me any difference b/c he's the expert.The timing in tt chips is written on them. And it's not advisable to run 35psi without knowing such things but to each his own.
Did Eric also know you were planning to run 87 octane?
ks
It does make a difference as every car is different. I'm pretty sure Eric would agree his chips works best when tweaked to what the car likes. Unless he is looking at your logs, there is no way for him to get it perfect. I'm also pretty certain most would agree you shouldn't run 35psi, especially on 87 octane, without knowing what your timing figures are; and not just what PL or the chip states, but actual verified timing with a light; tuning 101 on a high boost application imho.
Are you stating that you don't know or care what your new high hp Mustang is running for timing?
I agree every car is different and requires fine tuning and if I wanted to squeeze every last bit of HP from a car then I would fine tune the timing and AF, etc, but I don't. If the AF looks safe and no knock and I feel the car is running good then I'm happy, just like you do based on your comment above.
As far as the Mustang: I do not have access to the tune that is in the car at this time. When I get the scan tool back from being updated I hope to be able to look at the code but it was incrypted by HPP Racing so I don't know if I will be able to view it. The car was dyno'd/tuned on 93oct but I will get it retuned with 87 and Meth either this fall or next year and when I do will I care about the timing? Sort of, but not really. As long as it's around 18* and not some crazy number like 25* I don't care. Will I care if the timing is 17* or 18*? Nope. What I care about is the boost deviation, Fuel psi, AF and KR, etc.
If you want to care about your timing then that's up to you, enjoy tinkering with it. That's what it's about.
ks
What timing is in the chip may not be the actual timing.What do you think? I told Eric everything the car had and want I wanted to do so he programmed the chip. What timing he had in the chip didn't make me any difference b/c he's the expert.
ks
on multiple car and combos i have seen that the duel nozzle can support more timing with the boost,therefore you can get more aggressive with it.in the past i have run 2 m10's on a stock motor and 49 turbo, car ran great and could be very aggressively tuned,much more than the single 15.it really depends on how you want to tune and the combo.
How much more and did you do any back to back testing? Others have pushed 130mph on a stock longblock with a single m15 so I'm not seeing where your tune with a ta49 could have been more aggressive than that.
