I'll probably just email Julio directly on this one, but I figured I'll post here and see too. I have my car dialed in pretty well, however I'm thinking I'm running right at the edge of what my alky setup will support. Right now I have a single M15 nozzle on my alkycontrol system. My mods are below, but I have 60lb injectors running 70% duty cycle on pump gas and methanol at 22-23psi. I'm guessing I'm roughly in the mid-upper 500hp range. I haven't run it super hard at the track, but can damn near hit 120 on street tires with a 1500-2000ft DA. I have the dial on the controller knob set between 7 and 8, and the initial setting is set to start the pump out at 5v right now. It is really dialed in and AFR is solid at 10.9-11.0, but I run 20 / 18 degrees timing. Anything more will start to give a couple knock counts.
So all that being said, it runs great, but it seems like there is no room for growth with the single nozzle setup and based on a couple calculations I found online, the numbers show that the single M15 setup is topped out.
So....is it time to think about a dual M10 setup down the road if I decide to push more air through this thing with a bigger turbo or more boost?
