dr_frankenstein
Mad Scientist
- Mar 17, 2008
I am working on setting up the cam I need for my engine.
blown 4.1, 6V92 15% overdriven for 17-21lbs boost, 9.96-1 static compression, stock stroke, oliver 6.650 "window makers", stage 2 heads, dry sump.
I need opinions. Here is what I made for a pattern - though my ideas may be strange to begin with.
advertized duration 272/294
LSA 114*
Intake Lobe 6313 (comp cam)
Exhaust Lobe 6012 (comp cam)
Duration @ .050 (I) 242* (E) 256*
Duration @ .200 (I) 151* (E) 162*
Bigger? smaller?
looking to make 750-850 hp. Also need the ability to be able to grow into a larger blower such as a 8-71 or 10-71 for max boost pressure of 30lbs.
thanks.
LSA 114*
Bigger? smaller?
thanks.
