Setting cam sensor
pisano
I make the car top dead center, then I rotate it, standing in front of car facing motor, to the left(as if I were loosening a bolt) 1.45 inches. I drop cam sensor in gear dot towards pass fender and wires towards driver headlight then I turn clockwise to 7 or more volts then counter clockwise till it drops then tighten. What am I doing wrong? Car acts like battery is weak to start unless I randomly play with cam sensor what am i doin wrong
I make the car top dead center, then I rotate it, standing in front of car facing motor, to the left(as if I were loosening a bolt) 1.45 inches. ........... What am I doing wrong? ..............
You need to rotate to the right, 25 degrees AFTER TDC. ;)
After that, follow the rest of the procedure. :)
Top dead center is when the line on the balancer lines up with 0 on that piece of plastic right
