Dusty Bradford
- May 24, 2001
I'm gonna document the changes my car is currently going through here. I have taken it from a V6 Regal bought from an old lady, to a low 8 second street cruiser, to a 7 second street cruiser. Now with the big block it's capable of 7.20's around 195mph while still maintaining the street car appearance and only using an 8 point cage. I have always tried to compete at 200-300# over min weight. Well time has come for some serious changes. The stock chassis was a becoming a bear to handle. I have always shifted the car myself, trying to fight the car and change gears has become unsafe so I'm upgrading to a 25.3 chassis and the car will look drastically different on the interior.
The seats will be aluminum but covered in material, the back seat will be gone to make room for the cage needed at this level. The console will be gone so I can save weight and utilize an air shifter so I can keep both hands on the wheel. The ride height will be lowered to get the ic and cg down. The factory panel the upper control arms bolt to will be replaced with the "g-box" from David Lemmond. It's a much stronger steel piece that won't risk being twisted or broken with better ic adjustability. I will still retain the stock location springs and shocks but the heavy factory spring perch is gone and replaced with a much lighter spring locater attached to the roll cage. So far I have lost 150# of raceweight. Front fenderwells have to go to make room for snout bars to help take the flex out of the front frame section.
Pics of all work will follow.
