Yeah - great.
All show and no go.
I forgot to say thanks.
Ha ha ha ha you have a great since of humor.You will get it fixed.
Yeah - great.
All show and no go.
If and when you remove the 49 take it apart and look at the surfaces. The inside of the compressor housing will tell a big tale. You would also see radial scoring on the turbine scroll. Contact is what you are looking for.
Ha....its not nearly as complex as you fear. Pull the bolts on the backing plate, remove compressor housing being careful not to damage the big oring. You will get a good look at the back of the housing. The rest will become obvious. There may be a nick on the turbine scroll where the blade is forced to rest causing the no spin until you give it a nudge with your finger.....kinda like my wife.
Go into your house and go to the liquor cabinet. Grab yourself a nice tall glass. Fill it about halfway with ice. Pour your favorite whiskey over the ice. Sit in your favorite recliner relax and face reality. Your turbo is bad. Put it in a box label it with bisons address and ship it to him to rebuild. you will be satisfied
Just a little tough love good luck
Neither could I. I went through this about a year ago and like you, I did not want to admit the truth. I shipped my turbo the bison thinking that was not a damn thing wrong with it. When I got it back get stuck it back on, everything was perfectly fine. Except my wallet was a little thinner. I'm definitely going to stay tuned to see the outcome of this one. Again, good luck to you sir. Hope you get that pretty car fixed back on the road soon.
LOL........Sigh.
Big sigh.
At least I might be able to limp by on the stocker for a while - hopefully.
Bryan - Phoneguy - said about 4 pages ago he saw a new turbo in my future.
Blimey!
It's amazing how it went from beastly to cowardly in the span of an evening.
I feel like a little kid - 'I broke my toy!"
(Shrugs.)
I didnt read the entire thread but the following can/should be checked for as long as shaft and compressor spin free and the engine doenst have any misfire:
broke shaft (not likely without oil leaking everywhere.) seen this more than once and once it didnt dump much oil
shaft nut not torqued. Ive seen this and it was only a little loose but not loose enough to let the compressor move but not hit the housing and the thread locker still held
wastegate 100%closed. Ive seen them not
intercooler obstruction (not likely)
exhaust restriction (more likely) Ive seen this
Remove the air inlet and have a friend load the engine and see if the shaft stalls from the thrust.
Just got caught up on this thread and yeah, it takes little to spin a good turbo. The engine just idling should def do it especially with the puck closed. Prob even puck open too.
Stockers have been in the low 12's.
My 84 in Texas had a gutted cat and never failed. Another great byproduct of wasted spark
