OK Guys I need some help. I bet you audiophiles may get a good laugh at this but I need some advice. 2 years ago I put a system in the GN, using the product advice from Crutchfield and Circuit City, but a stupid mistake resulted in a blown amp. I’ve since had it repaired, and want to put the entire system back in the car. Here’s what I have; (CC means I got the components at Circuit City; CR means I got them at Crutchfield):
CR Kenwood KDC-217 head unit, 45Wx4
CR Kenwood KFC-6908 4-way 6x9 read deck speakers, 220W max, 55W RMS
CR Kenwood KFC-1368S 2-way 5 ¼” door speakers, 110W max, 28W RMS
CC Infinity Reference 3012cf 2-way 3 ½” door speakers, 90W max, 25W RMS
CC MTX Thunder 4122 Amp, details: http://www.epinions.com/614165_Kenwood_30W_x_2_Thunder_4122/display_~full_specs
CC MTX Thunder 8302 Amp, details: http://www.epinions.com/614193_MTX_Audio_75W_x_2_Thunder_8302/display_~full_specs
CC Infinity Reference 1020w subs (2), details: http://www.epinions.com/Infinity_10__Subwoofer_1020W__Subwoofers_REF1020W/display_~full_specs
CC Q-Logic sealed enclosure
I have all the power wiring, amp wiring, speaker wire, fuses and such to connect everything together. My only question is, how should I run it? In my opinion, when I had it hooked up originally, it didn’t sound anywhere near as good as I expected. I tried adjusting the settings on the amps, but I just couldn’t get it to sound that great. I’m thinking I did something wrong (installation), or this stuff just doesn’t match up and work well together. Keep in mind that I’m not looking for symphony-hall sound, but I’d like it to sound better than the stock 6-speaker system in my Grand Prix, which it didn’t.
So, my question to you guys is, how would you hook this up to sound the best with the equipment I have? I had the dash and door speakers running off the head unit, the 6x9’s running off the 4122, and the subs running off the 8302. Is this a good setup, or should I hook it up differently? Do I have enough amp to run the subs? What pieces would you recommend adding to improve the performance? Caps? Bass blockers? Or, in the worst case, another amp? Do I have something I can work with here, or is this just a horribly mismatched pile of parts?
Would appreciate your help!
Steve
Steve
