Here's some quotes that I ran across that seem to fit you!& I couldn't say it any better. Now pay attention!Wow are you a mind reader, are you sure you didnt miss your calling?
So what do you think she will run on the dyno?!?!?! :biggrin:
1hp@.5mph pushing it on to the rollers. :biggrin:
There isn't any vaccine for stupidity!
Wipe your mouth there's a tiny bit of Bull Sh#t on your lips
Why don't you slip into something more comfortable LIKE A COMA !
I'm busy now can I ignore you some other time!
Don't let your mind wander ,Its too small to be on its own!
Shhh That's the sound of nobody caring what you think.
Regards Lou!
tell that to your protoge..
this one applies to you.
your not far from a coma my friend.
you be very busy soon building Brent a new engine and trannie your wish came through.
it doesn't wander I said His sh** would blow up and it did.
It obvious you care enough to keep posting LOL.
Regards Lou!
The dip stick wouldn't pull out. I'll post video later today of the whole run.
Brent, I have some JB Weld to fix it good as new :biggrin: and then you can sell it to Wikedcrybaby as new, he will never know, he has a 245 hp street car. that won't break because he will never lean on it.
That does really suck that it did findly let go, but now for the new build up, drum roll please----------------------WHAT WILL IT BE
I don't know, I'm still in shock! I cried all night long about this LOL. I knew this was coming 150.000mi on the stock bottom end please, everyone said you'll love the car in the mid to low 11's but once you dip into the 10's things will start to break. "Morgan" Aka DripPan Well I guess that's the damn truth :biggrin: . I'm up in the air with my next build, but what ever it is, it's gonna be NASTY do to my Motor & Trans being completely wasted :frown:
Don't be in shock. Although very well documented and a well known "fact", 10's are the limit for a "stock long block". I was on a quest for 9's for 2 years on mine before in let go with 85,000 on the clock and a best of 10.03. Luckily mine grenaded on the burnout instead of your unfortunate run. You're very lucky, especially at Irwindale. It could have been very bad with the short shutdown area. It's sad that people such as Kevold, that are not "in the know" of exceeding 80mph in the 1/8mi, make light of your situation. I haven't seen the vid yet but I'm sure it was a handful at the top end. Good luck on the rebuild, and if have you any ?'s or need any stock parts(like I use) lemme know. Oops, I forgot, according to "people in the know" I'm just a ricer so what do I know? good luck
-scott wile
Now you can put a motor together to go with your full roll cage, it is certified to 7.50's or 8.50's im not sure, they keep changing rules, so there is your goal
