Inyector Opening
jowy
helo i have the xfi and the inyector aré 95 pound is ok that the inyector opening time is on 0.9 o have too go 1.0 o 1.1
Do you mean "injector opening time vs. voltage"? Each brand and size has it's own curve. The files for most are in the software. On my car, getting the right one made a big difference.
I still have the 1.34 xfi ,,, the injector timing retard was on 20 and the opening time on 0.9
In the old software you just adjust the injector opening time to raise or lower the curve. If your idle fuel A/F is good, then your injector opening time is probably correct.
Did it run well with that? Who set those parameters originally? Or, did you just buy the box used and that's what was in the tune? If so, I suggest seeing what voltage you have at idle. Then finding an "opening time vs. voltage" graph for you injectors. For example. If your Idle is 13.5v find that time on the graph. Then enter that as the number.
Or, you can just do what Cal says.:D
Yes i buy whit the tune but whit 60 inyector Now the aré 95
First change the injector size to what you have. Don't change anything else. Then start it. See what happens. Your set-up most certainly will require an entire re-map on just about everything. But mostly, it should start if the box was on a Buick. I would look into finding someone XFI knowledgeable in your area to give you a hand with the set-up. The details can be quite difficult to explain all at once in this forum.
That won't really work, since the curves of the two graphs are probably quite different. Also, the 1.34 software isn't necessarily using the value you input for your idle voltage. It trims that value based on different voltages. You would be much better of just adjusting that number until the A/F gets close with normal values (35-40) in the VE table at idle. Once it's close, trim the VE Table
If the car ran good with 60# injectors and you just upgraded to 95#, the VE Table should be real close. You will just need to change injector size in the "Fuel Calc Parameters" table and highlight the following tables and multiply by 63% (60#/95#):
Cranking Fuel Table
AE VS TPS Rate of Change
AE vs MAP Rate of Change
If you upgrade to 2.0, you will need to modify several tables not just the injector opening.
the voltage read 12.5 when on full throttle go 13.5 because the volt booster turn on
Yes, but wouldn't be most noticeable at idle if the opening time was off? What I'm asking is if you can't duplicate the whole curve isn't most important to get the opening time spot on at idle?. If this is correct then the other parts of the curve that you can't duplicate will end up getting blended in to the VE. No?
I believe he bought his box with the 60lb tune in it. That means his entire tune may need re-mapping. The car it came from may have a totally different motor build. Heads? Cam? Turbo? Displacement? I wouldn't trust a tune from someone else's car without looking deeper than just changing the Injector flow rate.
That's why I said he may need a little more help.
Yes, it is most important to get it correct at idle. That is why I said to do the way that I did rather then trying to use the value on the curve@13.5 volts like you wanted. The value you are putting in the 1.34 software is not at 13.5 volts. I will have to double check, but I believe it's at 12 volts. If so, then the actual injector offset is going to be lower than the value you put in the calibration. This is because you are actually at 13.5v instead of 12v. As the voltage changes at idle (fan cycling, hit the brakes, turn on the lights, etc..), you will have to rely on the O2 correction to keep things close. IMO, the battery offset table was the biggest improvement in the 2.0 upgrade.
Jowy,
Are you starting with a tune from a different engine? Or is this your tune and you just upgraded to larger injectors?
Actually, I used 13.5v as an example of voltage. If that was the case and it was that number... or some other number, it wouldn't matter. As long as typical idle voltage is used to calculate opening time from the injector's graph. Yes, the rest of the graph may be off, but who cares? It's going to be right where it's most noticeable.
I agree, the offset table was a huge help when I upgraded to 2.0. I have 160's and this made all the difference!
I'M still Learning on this computer ,,yes i need help on this ,, not only change the inyectors i upgrade the turbo too and only get 435 hp on dino on 20 pound
I'm afraid we are getting off track here, but my point was I wouldn't want to use the offset table of that injector like you posted. You are wanting to input the value at whatever his idle voltage is, yet the XFI thinks that value you input is NOT at typical idle voltage but at 12v. If you do it like I posted and adjust that value and get the idle A/F as close as you can, your VE numbers will be close to accurate. The resolution of that value is a tenth (1.1ms, 1.0ms, 0.9ms, etc..) so you are only going to get it so close.
