ThebigbadWolF
- Jun 26, 2013
Hello again everyone.
Hope all is well, i had some family issues so i have been away.
finally got my 87 GN running reallly good, and got to add a few mods.
So my mods are, RJC FMIC, 3inch down pipe, 48lb injectors, chip, scanmaster, RCJ air plate, new turbo(stock replacement) turbo tronics t43_sb-601-54-gnd_63
soooooo my goal was 15lbs of boost, however im only seeing 11lbs. I have an adjustable replacement wastegate as my old WG was welded for an extented arm.
I have the arm all the way in, and im still making 11lbs.
I have read up on this some,im not in tuner mode ( i have a hose coming from the trubo / WG into a Y going to the solenoid)
I had a RCJ boost controller but this is not designed for such low boost, the lowest i could get from the RCJ BC was 19lbs.
I dont honestly know how much boost i can run safely , but id like the run the most i can.
Alky is later, but for now i got the car running well, and want to get the most out of it till i do some serious modding.
PS, also have a scanmaster installed and running, i had a buddy check it out he said all my numbers are perfect, but it dont mean shit to me, is there a guide or online information that breaks down each field/option of the scan master, and good/bad numbers, what to look for ect?
i ask my buddy to leave it on knock since thats the biggest issue and even when i boosted to 22 lbs toying with the RJC i had 0 knock.
Thank you in advanced.
WolF
WolF
