hey guys i own that beretta the mods i have are as shown....
1996 beretta w/a 00' 3400, 3500 heads 3500 lower intake manifold, 36lb hr injectors, t3 t4 63ar 60 trim, front mount intercooler, greddy rs BOV, tial 38mm wastegate, 180* hypertech thermostat, fidanza flywheel, TG LSD, spec stage III clutch, ffp udp, tranzgenic cold air, walbro 255 lph, ffp dogbone, Ingall Camber Bolts, GM strut tower brace, z51 rear sway, fe3 front sway, new 92 5sp tranny, 92 subframes, poly control arm bushings, poly sway bar bracket bushings, poly endlinks, poly z51 bushings, carcustoms poly mount, kyb shocks and struts, eibach springs, battery relocated to trunk, TGP 2 bar map sensor, DHP Powrtuner, euro headlamps, euro tails, viper 791xv, and more to come soon...
and the spring in my tial is a 5.8 spring..that is all im running for boost...right now... lol
me and adam will have to line up at the track as soon as i get some slicks.. but i know by then ill be running upwards of 10psi which will hopefully knock me past 360whp
