BlackMetal
- Sep 29, 2005
Finished my install.
Pedal presses to the floor with zero effort. Barely returns. Brake light on the dash.
Bench bled the MC per the instructions from Dorman, it didn't come with the fittings for looping hose back into the fluid, instead just plugs, and said work the master cylinder until it became difficult to move it 1/8" of an inch, which I did patiently over a half hour letting any bubbles settle out.
I already did check the spring loaded valve in the pump that gave some people problems during their installs, mine is definitely not seized because as I unscrewed the fitting from the top of the pump it practically shot out at me.
Oh yeah last symptom:
