Hartline Performance THS
Status
Not open for further replies.
Sydwyndr
Admin
Staff member
I would like to thank Hartline Performance for sponsoring the Turbo Hot Street (THS) class in March for the Turbobuick.com Nationals!! I would like to extend a thanks to Kip for making this event one of the stops on the racing season for THS in 2010.
We specialize in sales,installation and tuning of all aftermarket fuel injection systems. Hartline Performance is an authorized distributor for the complete FAST-XFI product line, Accel, NLR Boost Controllers & Precision Turbos. Hartline Performance is an authorized distributor for the full line of FAST-XFI products. We have the most competitive prices with support after the sale. We also offer a full line of Precision Turbos, Champion Racing Products, H&R parts suspension, Aerospace Brakes and much more. We can install any aftermarket fuel injection system from FAST, Accel GEN 7, and Motec. Whether it is a Buick, Porsche, Mustang or even an Airboat, We Can Do it ALL!! Need tuning? We specialize in high performance aftermarket ECU tuning. Hartline Performance has tuned many of the top race cars in the country. We have done them all Pro 5.0, Drag radial, Imports, even airboats! Let our tuning take you to the winners circle.
321.722.1563
The THS class will pay $500 win / $200 RU. Entry fee is $25. This format will be heads-up/pro tree. The RRA for this class will be Kip. There must be a 5 CAR MINIMUM in order to run the class. All entries will be given a Hartline Performance decal that must be on the car before first round of qualifying on Friday. I would again like to thank Hartline Performance for their sponsorship and continued effort in the Buick Community offering their customers parts & service!!
Should be another great class at the 2010 TurboBuick.com Nationals!
Kip, please post the THS rules here as well...
Is Kip sponsoring this at the turbobuick.com event or is turbobuick.com sponsoring it? :confused:
See ya,
Here are 2009 Rules
As soon as the 2010 Rules are final I will make sure they are posted.
As always if someone has a question about the rules just post in the THS section and someone will get back with you asap.
Turbo Hot Street – THS
General
- Heads-up pro tree start and pro ladder.
- No peer technical inspections relating to safety equipment rules by class participants or peers, track safety technician personnel will make all rulings on track safety related items.
- Any car is subject to re-weigh and re-tech immediately after final round or any other time.
- Any entrant caught trying to deliberately break the rules will be disqualified from the THS class.
- Nitrous Oxide not allowed.
Chassis/Exterior
- Seat belts, lights, horn, and windshield wipers must be operational.
- Aftermarket fiberglass or carbon fiber bumpers and bumper filler panels allowed.
- Minimum car weight w/driver must be at least 3500 pounds with iron heads, 3650 pounds with aluminum heads.
- Complete stock, painted Turbo Regal/Grand National body required.
- Stock wheelbase required (108.0” measured)
- Engine/firewall must be in the stock location.
- Stock operating glass windows and windshield required no lexan.
- Factory stock suspension locations required w/any type stock location shocks.
- Any suspension stabilizer/reinforcement bars or traction enhancing devices are allowed.
- Sway bars may be removed.
- No ladder bars or coil over equipped rear suspensions.
- Outer frame rails notching allowed. Inner frame rails remain in the stock location.
- Reinforcement at inner rear frame rail allowed.
- No quarter panel modifications except rolled inner lip.
- Minor modifications to stock rear wheel wells (no mini tubs).
- Factory stock appearing inner front wheel wells required. Trimming allowed for downpipe clearance.
- No wheelie bars.
- Brake system must be Power Master or vacuum boost operated, or manual brakes allowed.
- Brake system line locks allowed.
- Driveshaft safety loop required.
- Driver’s name on side window allowed. Sponsor/vendor decal is acceptable on the rear and quarter glass windows.
- A maximum of 2 hood mounted gauges are allowed.
Engine
- Stock 109 casting block.
- No Stage 2 iron or aluminum heads allowed.
- Any valve covers and oil pan allowed.
- Factory stock intake manifold or cast intake (BG Customs or Champion intake). External welding, cold weld epoxy, or putting not allowed. EGR block-off plate allowed.
- Factory coil pack bracket may be modified and right wiper rod maybe be modified for clearance if using an aftermarket cast intake.
- Factory stock plenum w/spacer or aftermarket cast aluminum intake plenum allowed.
- Any size single modified stock or aftermarket throttle body allowed. Single throttle plate only.
- Any type stock location exhaust headers are allowed Welded in EGT gauge probe bungs are allowed.
- Any single or dual exhaust system allowed. Must muffle and exit in stock location(s) (3.5” max size). Exhaust must run through mufflers in competition.
- Any diameter downpipe size from the turbo allowed. Downpipe must be routed down through the stock location, no flex pipe allowed.
Turbo
- One (1) 3-bolt turbo allowed and in the factory stock position/orientation.
- The largest allowable turbo compressor is up to and including 67mm. Maximum opening size anywhere on the compressor housing inducer must be less than 68.5mm. One single compressor opening only no internal ported shrouds.
- The compressor housing must be 3” inlet x 2” outlet.
- The turbine housing must be a 3 bolt housing that was available November 1 of the previous year. Factory stock appearing turbine exhaust to downpipe connection must be used.
- Any wastegate configuration acceptable, external wastegate(s) must be plumbed back into the exhaust system, no external dumps allowed.
- No billet wheel turbos allowed until the potential of these new turbos is known.
Intercooler
- Any stock location or front mount air to air intercooler is allowed.
- A front mount intercooler may not extend down below the bottom of the stock located radiator support. Not including the piping.
- No liquid intercoolers, intercooler external spray cooling, or add-on cold boxes allowed.
Engine Management & Fuel System
- Stock or modified stock ECM, aftermarket fuel management system (DFI, F.A.S.T., Motec, Etc.) are allowed.
- Factory Stock Appearing (Type I) or (Type II) DIS cam position sensor required.
- No individual coil per spark plug ignitions allowed.
- No distributor ignitions allowed.
- Any air induction system allowed, but no hood scoop.
- Any fuel pump(s) configuration/location allowed.
- Voltage increasing and fuel pump hot wiring devices are allowed.
- Factory stock fuel rail or aftermarket rails allowed. Aftermarket and stock fuel rails may be modified.
- Any type fuel pressure regulator allowed. Any fuel injectors allowed, 7 maximum. The 7th injector MUST get its fuel supply from the fuel rail.
- Factory stock fuel tank w/ sump addition allowed.
- Gasoline fuel only.
- Alcohol injection allowed, must be sprayed in through the air intake system “up-pipe”.
Engine Compartment
- All Air Conditioning and heater components installed and in the stock location w/belt in the stock location.
- Power steering operational w/belt in stock location.
- Stock alternator operational w/belt in stock location.
- Stock water pump operational w/belt in stock location.
- All engine accessories must be driven from the same belt.
- Any engine compartment dress-up allowed.
- Battery must be in the stock location.
- Any stock type/location electronic engine cooling fans allowed.
- Any stock or replacement radiator in stock location allowed.
Transmission
- Must have 200-4R transmission.
- Any torque converter allowed.
- Any transmission cooler and pan allowed.
- Transmission brake allowed.
- Must have 8.5” differential housing, +/- 1” allowance.
- Limited-slip differentials or spool allowed.
- Any gear ratio with factory stock or reinforced differential cover allowed.
Tires & Wheels
- Any matched set of (4), 15” diameter chrome steel or aluminum wheels allowed.
- Rear drag slicks w/sidewall designation up to and including 28” x 10.5” – 15”. No “W” tires allowed. Rear DOT street tires with sidewall designation up to and including 28” x 12.5” – 15” size tires allowed. Rear DOT Radial tires with sidewall designation up to and including 275/60/15 allowed. Rear tire footprint when installed on a rim and mounted on the car can not exceed a maximum of 10.6” in width at 10 psig checking pressure. Tires may not be shaved at the tread edge to meet the 10.6” maximum width rule.
- Front tire footprint must be at least 3.5” wide.
Interior
- Full stock appearing interior required.
- Race seats are allowed only if the seats are attached to the rear crossbar of the roll bar and seats are painted and upholstered to match the factory interior.
- Any transmission shifter allowed.
- Any additional aftermarket gauges allowed.
Kip its an inside joke,It has nothing to do with you or THS.
sorry if it came off that way.
Otto, I did not see it as being a jab at me or THS. I saw it as a jab at Clint and the TurboBuick.com Nats. Hope that is not the inside joke. These guys are doing some thing good and I want to see it stay that way.
See ya, Kip
Kip as the rules have been posted by Collin do you approve of them and are these the official rules as they are written?? Want to make sure that there is no discrepancies listed in the posts above because I wasn't able to find them anywhere.
Hi Clint. yes those are the rules we used in 09. If you look in the THS section of this board you can also find them posted there and on T6P also..
Thanks, Kip
When is the BB Turbo going to be decided upon?
Hi Shane, rules should be set in a few weeks. Right now we are trying to get next years schedule set. Now that it is clear we are doing TurboBuick. com nats me and Cal need to figure out Reynolds.
Am I maybe smelling a car from your stable coming out??????
Thanks, Kip
"All entries will be given a Hartline Performance decal that must be on the car before first round of qualifying on Friday".
I guess You can count us out on THS at this race. See you all at BG.
Did you really need to post this here simply over a little decal?? Why even respond and say anything at all?? Have you talked to Cal about your issues??
Good luck in BG!
You wanna be a hero? come run the race and don't run the decal and don't take his money.
See ya, Kip
Has nothing to do with Clint or the Nats either and will stay inside.
I plan to be there and I think the car I just built for my current employer falls into these rules and will race the class.
I personally think its a pretty cool class that fits many street driven cars,nice job on it.
Thanks, Kip
May TFS car would be perfect for this class. We have already installed a BB 67 though:cool: Still have the old one but isn't worth going back to me so...
This will be very interesting IMO, can't wait!
Status
