vacuum 6
I have chuckers
- Jan 6, 2006
Over the years I've moved to a smaller turbo, updated my trans and moved to a different converter. The turbo spools stupid fast killing the MTDRs (recovers quickly) and causes transition knock. Alky turn-on is factory setting. Initial is set to 12 o'clock. Tested alky pump voltage with gain knob at 8, voltage read 6.12 No leaks in the alky system.
Side note: no transition knock when octane is added. I don't have log files to share. Looking for feedback on how others resolved this.
I'm thinking three things
1) lower the alky turn-on point
2) Install Julio's check valve.
3) add fuel to first gear
