i believe its the complete contrary synthetic oils are thin when cold and get thick hot . you can try it or your self put synthetic oil in your car
is you use 10w30 mineral oil then use a 5w30 synthetic the oil pressure will not be as high at startup and will be higher when hot and warm and most noticeably at idle.
the 30 indicates the thickness of oil at a certain temperature so mineral oil and synthetic will be the same at that temperature and then move apart as the synthetic gets thicker as it gets hotter. this is my understanding and i have tested this and now i run exclusively synthetic oils.
and this is the whole premise of synthetic oils as we want thin when cold for easier start and thick when hot to support the loads.
-30 oil or -40 oils will be even thicker at starts and even thinner when hot as they dont have the viscosity modifiers as any 0w 5w 10w 15w oils have.
feel free to correct me but this how i understand it i ask you to try it for your self!
i'm currently running 0w 20 synthetic in my turbo buick engine and at 210 f coolant temps i have 25 psi oil pressure at 800 rpm idle
