Seal the whole back of the fan?
Any automobile oil is made to be thick when hot, and thin when cold, like 20W-50?
I have dealt with synthetic oils in Buicks before you were alive, and in all the many I have owned and serviced, ALL of them have better oil pressure with regular oil than synthetic. First you need to understand the GN turbo V-6 engine technology and design is from the 1960's.
You may be quoting some info you have found, but many owners here have also changed from synthetic oil, and all have seen an improvement in oil pressure, cold and hot, and less leaks as well.
215°! Isn't that damaging hot? Is that a normal temp for tb ?
conventional oil 15x40 10w30 doesn't mean the oil is 10 when cold and 40 when hot .. put oil in the freezer and it will get realy thick and if you ever drained your oil when hot its like water. the 10w or 15 w is a different scale. from the 30 or 40 .
What a multi-grade oil does, is it's a base weight oil (10W) with additives to make it behave more like a thicker (40) weight oil when the temperature is higher. This way at lower temps it still flows just like the base weight. A 0W30 oil will be a base oil of 0 (extremely thin) so it will flow at very low temps but at higher operating temps it will behave like a 30 weight oil. It will never be a 30 weight oil but it's characteristics behave like one.
what do you mean behave like 30 ? and what characteristics is there ?
So what is the normal temp?
Sent from my HTCONE using TurboBuick Mobile mobile app
Just what I stated. It won't be thick but if you've ever heated oil or sprayed it on a heated part (like spraying WD-40 on a torch heated part) it will run off fairly easily. When the additives are in it then it will not flow as easily at higher temps. like it was water.
well viscosity is the resistance to flow ..
I'ma fix the oil leak and see what happens.Could that be the cause?
It's more than a viscosity modifier that's used. The actual viscosity is the same.
