my CAS v2 had the 2.5 inlet pipe from turbo to IC , he (tony dequick) only went to 3 later on because thats what people wanted
my turbo was 2.5 outlet and
ran it for years like that at 10.50s. going to a V1 FMIC with 3" pipes didnt make any real difference
bends on the other hand are big restrictions , if you have to have bends in the pipes like short radius 90s or 180s kill flow
the bigger the pipe on those bends the better it will flow , and changing up the pipe sizes suddenly is also bad for flow (fluid dynamics and air acts similar to water) , they need to transition slowly otherwise the turbulance will create a restriction
the v2 FIC does have 3" inlet and the elbow into the IC is made into the ic so theres less restriction at those bends so going from a 2.5 pipe to a 3" there wouldnt be much gain
oh and is that sig for real 11.61 118 on stock turbo and intercooler ,and you're asking advice on whether 3" pipes is a good idea .. really ? im calling BS
