Final THS Rules for 2010
Slow91z
Turbobuick.com Helper
Staff member
2010 Turbo Hot Street Rules
General
1. THS will be run with a “heads-up” pro tree start and off of a pro ladder.
2. No peer technical inspections relating to safety equipment rules by class participants or peers. The track safety personnel will make all final rulings on safety related items.
3. Any vehicle is subject to being re-weighed and re-inspected (tech) immediately after the final round of eliminations or any other time deemed necessary by the Race Rules Administrator (RRA).
4. Any entrant caught deliberately breaking the rules or deliberately attempting to break the rules or breeches that violate the spirit of competition will be disqualified from THS.
Chassis & Exterior
1. Lights, horn and windshield wipers must be operational.
2. Aftermarket fiberglass or carbon fiber bumpers and bumper filler panels are allowed.
3. MINIMUM vehicle weight including the driver MUST be at least 3500-pounds for a vehicle equipped with IRON heads and 3650-pounds for a vehicle equipped with ALUMINUM heads.
4. Complete stock and painted T-Type, Turbo Regal, Grand National or 1989 Pontiac Turbo Trans Am body required.
5. Stock wheelbase is required.
6. The engine and the firewall must be in the stock location.
7. Stock operable door glass windows, glass quarter windows (where applicable), glass front and rear windshields are required. No lexan.
8. Factory stock suspension locations required with any type stock location shock absorbers.
9. Any suspension stabilizer/ reinforcement bars or traction enhancing devices are allowed.
10. Sway bars may be removed.
11. No ladder bars or coil-over equipped rear suspensions.
12. Outer frame rail notching is allowed. Inner frame rails must remain in the stock location.
13. Reinforcement at the inner rear frame rail is allowed.
14. No quarter panel modifications except rolled inner lips.
15. Minor modifications to the stock rear wheel wells allowed but no mini tubs.
16. Factory stock appearing front inner wheel wells required. Trimming for downpipe clearance is allowed.
17. No wheelie bars.
18. The brake system must be a Power Master or vacuum boost operated, or manual brakes are allowed.
19. A brake system line-lock is allowed.
20. The driver’s name on the side window is allowed. Sponsor or vendor decal(s) are acceptable on the rear window and rear quarter glass windows (where applicable).
21. A maximum of two (2) hood mounted gauges are allowed.
22. The Turbo Trans Am must use the factory production stock K-member.
Engine
1. Any production Buick V6 engine that was available from the factory in a passenger vehicle is allowed.
2. No Stage 1 or 2 iron or aluminum heads or engines are allowed.
3. Any type of valve covers and oil pan is allowed.
4. The factory stock intake manifold or cast intake manifold (i.e. Champion or BG Customs) are allowed. External welding, cold epoxy welding or puttying for performance enhancement is not allowed. An EGR block-off plate is allowed.
5. The factory coil pack bracket and right windshield wiper rod may be modified for clearance IF using an aftermarket cast intake manifold.
6. The factory stock plenum with a spacer or aftermarket cast aluminum intake plenum is allowed.
7. Any size single modified stock or aftermarket throttle body is allowed. Only a single throttle plate is allowed.
8. Any type stock location exhaust headers are allowed. EGT guage probe bungs that are welded into the headers are allowed.
9. Any single or dual exhaust system (3.5” diameter max for either) is allowed. Systems used must muffle and exit in the stock location(s). A closed (muffled) exhaust must be used during eliminations and qualifications.
10. Any diameter downpipe size (from the turbo) is allowed. The downpipe must be routed through the stock location. No flex pipe is allowed.
11. The “Engine Rule”, number one (1), is subject to review and revision following the completion of the 2010 season.
Turbo
1. All turbochargers, including billet wheel turbochargers, meeting the below listed specifications available prior to January 1st of 2010 are allowed.
2. One (1) 3-bolt turbo mounted and oriented in the factory stock position is allowed.
3. The largest turbo compressor available up to and including 67mm is allowed. The maximum opening size anywhere on the compressor housing inducer must be less than 68.5mm. One (1) single compressor opening only is allowed. No internal ported shrouds are allowed.
4. The compressor housing must have a three (3) inch INLET and a two (2) inch OUTLET (i.e. 3” x 2”).
5. The turbine housing must be a 3-bolt housing that was commercially available on or before January 1st of 2010. The factory stock appearing turbine exhaust to downpipe connection must be used.
6. Any wastegate configuration is acceptable.
7. The “turbo rule”, number one (1), is subject to review and revision following the completion of the 2010 season.
Intercooler
1. Any stock location or front mounted air-to-air intercooler is allowed.
2. A front mounted intercooler may not extend below the bottom of the stock located radiator support. This does not apply to the front mounted intercooler piping.
3. No liquid intercoolers, intercooler external spray cooling or add-on cold boxes are allowed.
Engine Management & Fuel System
1. A stock or modified stock ECM or an aftermarket engine management system (i.e. FAST XFI, Accel DFI, MoTec, etcetera) is allowed.
2. A factory stock appearing (Type I or Type II) DIS cam position sensor is required.
3. No individual coil-per-sparkplug type ignitions are allowed.
4. No distributor ignitions are allowed.
5. Any air induction system is allowed but no hood scoops.
6. Any type of fuel pump(s), pump(s) configuration and location(s) are allowed.
7. Voltage increasing and fuel pump “hot wiring” devices are allowed.
8. Factory stock or aftermarket fuel rails are allowed. Modification to rails (either type) is allowed.
9. Any type of fuel pressure regulator is allowed. Any fuel injectors are allowed up to a maximum of seven (7) injectors. The seventh (7th) injector MUST get its fuel supply from the fuel rails.
10. Factory stock fuel tank with a sump addition is allowed.
11. Alcohol injection is allowed. It must enter the engine through the “up-pipe” of the air intake system.
12. Gasoline fuel only is allowed.
13. The use of nitrous oxide is NOT allowed.
Engine Compartment
1. The power steering must be operational, with the belt, in the stock location.
2. The stock alternator must be operational, with the belt, in the stock location.
3. Any engine compartment “dress-up” item is allowed.
4. The battery must be in the stock location.
5. Any stock or replacement radiator mounted in the stock location is allowed.
6. 1984-1985 Grand National/ T-Types, i.e. “Hot Air” cars, running in hot air configuration, may compete without factory installed air conditioning components. The factory heater box must remain intact.
7. Any car configured as a 1986-1987 Turbo T/ Grand National or 1989 Turbo Trans Am MUST have all factory installed air conditioning and heater components.
Transmission & Differential
1. Vehicle must use a 200-4R transmission to transmit power from the engine to the differential.
2. No other type of transmission is allowed.
3. Any torque converter is allowed.
4. Any transmission cooler and transmission pan is allowed.
5. A transmission brake is allowed.
6. Vehicle must have the factory 8.5” 10-bolt differential housing with a +/- allowance of one (1) inch. Turbo TransAms must use the factory production differential their vehicle was originally equipped with (with a +/- allowance of one (1) inch).
7. Use of a limited slip differential or a spool is allowed.
8. Any gear ratio with the factory stock or reinforced differential cover is allowed.
Tires & Wheels
1. Any matched set of four (4) chrome steel or aluminum wheels are allowed.
2. Rear drag slicks with a sidewall designation of up to and including 28”x10.5” are allowed. No “W” tires are allowed. Rear DOT street tires with a sidewall designation of up to and including 28”x12.5” are allowed. Rear DOT radial tires with a sidewall designation of up to and including 295-55 are allowed.
3. Rear tire footprint when installed on a rim and mounted on the vehicle cannot exceed a maximum width of 10.9” for DOT radial tires and 10.6” for drag slicks and rear DOT street tires, at 10 PSI checking pressure. Tires may not be shaved at the tread edge to meet the 10.9”/10.6” maximum tire width rule.
4. Front tire footprint must be at least 3.5” wide.
5. Tire sizes allowed are subject to review and revision at the completion of the 2010 season.
Interior
1. A full stock appearing interior is required.
2. Race seats are allowed only if the seats are attached to the rear crossbar of the roll bar (where applicable) AND the seats are painted and upholstered to match the factory interior.
3. Any transmission shifter is allowed.
4. Any type and number of additional gauges are allowed.
  • THS Final 2010 Rules.doc
Not trying to stir the pot but what is the reason for the 3"x2" specs for the turbo?
Even when I had a 66mm turbo on my car I went with the 4"x2.5"
I know that, just wanting to know why?
Trying to keep the cars in the 10's ?
The turbo leaves our car out.
Not that I own a TTA,but the rear end rule should be opened up for them.
the stock 9 bolt is **** and the power levels this class will run and upgraded rear would be my first upgrade.
A couple quick reasons:
One when I started the class many people said I was allowing to large of a turbo by going with the 67 so I decide lets cap it at a 3x2 67mm turbo. There was even some who wanted a TE44 as the limit. No way to please everyone.
Two it makes tech a little easier as it is quick to see a 4 inch inlet. An S cover on a 70 looks the same as on a 67 so ever 4 inch cover turbo car would have to pull the air intake hose/pipe off.
Take care, Kip
Sorry to hear we lost you on the turbo rule. Maybe if you can make a race with the car you can borrow one. If at the time I have something laying around I will be glad to help.
On the TTA,your opinion is valued but understand that if we let say nine inch fords rears in for them some of the TR guys would have formed a lynch mob if we did not let them have one.
Take care, Kip
Take care, Kip
Thanks for the offer.we will see what happens.
I understand your thought on the rear end rule,but the
Buicks atleast came with a 8.5 rear,just figuring this may keep
some of the TTA guys from coming out.
It is cool that they are being allowed to join though!
This is a dead issue imo. I brought this up months ago but it staying 3", 2". Any air to air stock location or front mount intercooler is allowed but still required to run the small comp cover. Too bad. I have a very strong combo that will run at least a half second faster than anyone in this class has so far but im not about to send the turbo back to get the E cover.
I always find it amusing how some rules "Only" benifit the guy making the rules vs. benifiting the MAJORITY.....:rolleyes:
Bison , How fast is your car , and how fast has THS run?I saw a 10.20 something and you are .5 quicker than that? So you have run 9.70 in THS legal trim. Wow that is impressive!!
Wow that's an interesting take on this. You make it sound like it's a rule allowing a one off set of heads that only the maker of the rules has possession of. Anyone can buy a 3" inlet turbo.
Not going to run THS because of the turbo. Im not to keen on the tire sizes allowed either. Pretty much requiring re-gearing for optimization if you stay with a 28" tire height. Im very fond of the Phoenix 28.5x9 slick with the stock 3.42 gears. They are a no go according to the rules. The 295/55 DR may prove useful if the measured installed height is over 28" but i doubt it. The car has the the power to go 9.60 with a 1.37-1.39 60'. Ill post what it runs this spring. With 10 gallons in the tank a and me in the car @230lbs im right at 3660lbs.
Thats not what he is referring to. He is really saying most guys that run the kind of power to run competitively in THS already have front mounts and have had compressor covers larger than the E cover for a long time before THS was even thought of. If it was up to me i would have allowed any compressor cover to attract as many into the class as possible since it is new and id want some big dogs in it to set the bar. If alky injection is used properly you can recover almost all of what is lost with the smaller cover. It would be one thing if the E cover was an easy swap out for the owner but it isnt. It requires a different backing plate and therefore the turbo needs to be sent to the manufacturer for a swap out leading to aggravation. As far as the heads thing goes that is very true. The heads could have anything done to them but only need to appear as manufactured on the outside. Keep in mind most guys arent building a car specifically for THS including me. They are trying to run what they have. If they were building a totally new THS setup these rules wouldnt matter at all. Most will be adapting their cars so they are legal in THS. Some like me will not be. No big deal. It is what it is.
No offense Bison, but GNBRETT said benefits the guy writing the rules...I see no benefit, everyone has the same restrictions (in this case the turbo cover) so it's not benefiting the writer of the rules, or anyone else for that matter.
Car count is a whole different conversation than what I perceived GNBRETT to be referring to.
Also (and this is JMO), if someone was serious about coming out and being the big dawg in this class changing the turbo cover shouldn't be enough to deter them.
Bison, Why would you want big dogs in to set the bar where the average Joe dosent have chance to compete?That is not a way to gain car count.
Bison, I have asked for Brett to expalin his statement so we will all know what he meant.
You did see that front mount intercoolers are legal? Your comment about them and the compressor covers makes it seem like you thought they were not to me.
See ya, Kip
Just to let everyone know where the races will be held.
None of these threads are stickies, so i thought i would copy and pasted these.
Too bad they are far from me, i have all those mods done already on my cars.
But they are slow :)
2010 THS schedule
Turbobuick.com Nationals
March 15-20
Burlington, NC
20th Anniversary Buick Race Day
May 21-23
Norwalk, OH
Buicks @ Bunker Hill
June dates to be announced
Bunker Hill, IN
BPG Nationals
July 30-Aug. 1
Columbus, OH
Midwest Buick Challenge
Dates TBA
Osceola, IN
Southern Buick Shootout
Nov. 5-6
Reynolds, GA
Bison, Why would you want big dogs in to set the bar where the average Joe docent have chance to compete?That is not a way to gain car count.
Some self proclaimed "Big Dogs" like to run their Weiner cleaner about what they could do. :roll eyes: Its much easier to tell someone what you can do v/s coming out and showing them. Maybe adding SHOW ME to the rules might help. Still waiting to hear about the 9.50s car from last year showing up.
