josh rosaaen
- Nov 29, 2012
431rwhp 440torque
I'm hoping to run a low 7's be nice to get a 6.99.
That would make me more then happy. Track don't open till April so hope i can keep it going till then just going to do my interior over the winter and install a wide band and my vacuum brake setup and red armstrong double pumper I have sitting in the boxes. When I get home I'm going to get the results of the dyno so I can see what rpm and it was at and if there is anything else I can get out of it. I'm pretty sure I can get a little more boost if I want to.Your combo is capable of running easy 6's if the tune is correct and you can 60'. I have less in my combo and can run mid-high 6. Let us know how she runs at the track.
That sounded a whole lot more healthy than the numbers are showing...
Sounds great and looked like much more then 431rwhp...
It would be great if it did haven't gotten a chance to look at the print out yet. Is there anyone with similar combo that has there car dynoed. I think it sounds good and the guy tuning says it's running great so maybe there is more to squeeze out of it. I'll see how it drives thats what matters to me. I'm sure I'll get the guy with a sbc chevy and it a chrome kit saying his car has 500hp lol. Seems to be a number everyone gives me.
I may try a few more in the future I want to take it to the track first and see what it does first and see if I can reach my goal.Sounds mean! Throw a few more lbs of Boost add it.
Have you ever had your car on the dyno? Just wondering if you had similar numbers?Your combo is capable of running easy 6's if the tune is correct and you can 60'. I have less in my combo and can run mid-high 6. Let us know how she runs at the track.
What exhaust are you running? Sounds good. Do you get drone at cruise?
Bryan
I think the exhaust is a magna flow setup I'll check when I get home.I agree with both of you ......from what I can remember my car didn't seem to respond as quickly as his did at roughly the same hp.
Mike what combo do you have is it similar to mine?
Not with the current combo. With my TE-61 turbo it only dynoed at 411 hp on A Mustange dyno. A Dyno Jet dyno would probably have given higher numbers.Have you ever had your car on the dyno? Just wondering if you had similar numbers?
