car wont start
78olds
the probelm i am having is that the feul pump went bad so i put in a new fuel pump its is a sx fuel pump so the guage is reading 45 at cranking now so i have presure then i check for spark and it has spark the car want to fire but it doesnt the comb i have is a small block chevy twin turbo and it has the fast system bank to bank if you could give me some ideas would be great thanks dave
Check the map plug and vacuum line to it.
You say this is a twin turbo sbc?
How about a pic? :biggrin:
i check the map plug and the vacum line any everything is ok how could you see if the map is bad thank dave pic will come soon
I'm not real familiar with the fast b2b but generally speaking, the map signal should should be somewhere around 98-100kpa key on engine off.
Maybe DR BOOST could chime in.
got the car running now but its running rough is there anyone that has a base line tune thanks dave
