A ApullinV6 New Member Joined Oct 14, 2001 Mar 27, 2007 #1 I hear differences of oppinions on what bolts you should replace when rebuilding a engine. What bolts can you reuse if any? I had planned on buying all new for crank, rods, heads... do I need to? What is the best head gasket to go back with?
Jerryl Tall Unvaccinated Chinese Guy Joined Dec 14, 2004 Mar 27, 2007 #2 ApullinV6 said: I hear differences of oppinions on what bolts you should replace when rebuilding a engine. What bolts can you reuse if any? I had planned on buying all new for crank, rods, heads... do I need to? What is the best head gasket to go back with? Click to expand... Head bolts need to be replaced. Advice/input on replacement of the other bolts depend on your answer to this; What is your goal?
