Okay, I bought this trans off a board member, don't recall who now as its been awhile. Anyway he stated its to be used with a non lock up converter. The converter was included in the sale. Anyway this is what happens and I wondering if this is a characteristic of a non lock up tranny or not. While driving, the car shifts as normal 1st, 2nd then to 3rd... My shifter is in OD, when I shift down to third nothing happens, when I shift back to OD, all stays the same until I let off throttle...it then drops in RPMs while in OD until I apply throttle again as if I put it in neutral. When I do this after shifting into 3rd it stays in third and coasts in gear with rpms lowering with speed versus the aforementioned dropping in rpms and coasting as if in neutral...hopefully I'm explaining this so that it makes sense. Anyway this is the first trans I have had that is a non lock up. Not sure if this is normal or not.
