Drove car for the first time in a couple of weeks yesterday and while driving noticed did not come on boost well, felt slower and boost only rose to 14psi....slowly.
Drove car back home pulled off boost controller and checked other things like hoses and such out everything checked fine re-installed boost controller after turning it in some more (rjc controller). took for a drive (evening much cooler) car felt better but did not make boost past 11 in first 14 in secound and 16 in third....verified through both boost guages. pulling into the garage shut off car as i turned the key off i heard a mettalic pop...not real loud but it was louder than motor winding down. Now car will not start it sounds real funny when cranking almost like it is free spinning but motor is turning over, cam sensor is turning. fuel is ok, crank sensor is ok, hoses and such OK - I will start working on it to get more information.
mods - ta49-boost controller-translator-42.5 injectors-adj. reg.-255pump w/ hot wire-rjc plate - built trans / ATI converter-exhaust cat-back - 140 alt.
any help
any help
