I have recently installed both items. Both work great! On the 2 step launch control I can easy reach/exceed 10 psi of boast. At this level the alky turns on and there is a slight hesitation upon launching the car. Has anyone successfully integrated the 2-step switch voltage into the violet wire of the alky kit? This should delay and or reduce the amount of alky during the 2-step boost / launch time frame.
However I am concerned that I may introduce detonation by eliminating/reducing the alcohol at this boost level.
Thank you
Thank you
