11secmonster
- Jul 11, 2005
1999 t/a 11 second monster with cold ac,mint
JUST TOOK IN TRADE RECENTLY AND IT OR MY SRT-8 NEEDS TO GO.....15K...CAR IS IN NR MINT CONDITION THRUOUT!....HERES A VID FROM GUY I BOUGHT IT FROM.....AND LIST OF GOODIES!!OVER 10K JUST IN PARTS WITH RECIEPTS ,ETC.....CAR IS BAD TO DA BONE AND LOW 42K MILES!RARE CHAMELEON COLOR!!!CAR IS IN MY GARAGE IN SOUTH FLORIDA.CLEAN TITLE IN HAND. THIS IS A STEAL AND CAR IS DONE RIGHT.@ 480RWHP ON MOTOR.
Image hosting, free photo sharing & video sharing at Photobucket
1999 Pontiac T/A Blue Green Metallic
42k Original Miles,ice cold ac!!,very streetable!hooker exhaust!
AFR 205 Heads with 921 springs
Traks Cam
Fast 90 Intake(ported by Jeremy Formato)
NW 90 Throttle Body
Ported Oil pump
Hardened Push Rods
Speed Inc Fuel Rails
42lb InjectorS
Stock Bottom End
Moser 12 Bolt w/spool 3.73 gears narrowed 3" on each side
Boyd Coddington Timeless 2 wheels,17x9.5/17x11 Custom offset.
Vredestein Tires
Hawks Brake Pads
SJM ABS delete
BMR K-member/a-arms(upper and lower)
Transmission Physicians built 4l60e
4000 n20 Vigilante stall
MTI Lid
Pacesetter Long tubes/tsp ORP with hokker cat-back
Aluminum n20 Driveshaft
BMR Adjustable LCA
Arizen Seats
UMI Torque Arm w/DS loop
RaceTronics plug and play fuel system
Grant steering wheel
Electric Water pump
Underdrive pulleys
Wideband in car
Qa1 Front struts
Comp Eng rear shocks with bmr springs
Aftermarket polished aluminum valve covers
Suncoast Raptor Hood
California Indoor Car cover
UMI Drag Sway Bar
New Aftermarket black carpet
Rear seat delete
Edead Sound Deadener on the floor and doors
Both windows have had door crack fix to prevent normal t/a panel,problem
Both Window motors have been replaced
Passenger had relay kit to roll down faster
200a Alternator(car idles with radio blasting without dimming)
Big 3 wire upgrade
2 Re Audio 10's in stealth boxes
Polk audio seperates in doors and sails
Rockford Power 1000 5 channel amp,Alpine head unit.this system rocks!!!
mikeygold@yahoo.com
Traks Cam
NW 90 Throttle Body
Ported Oil pump
Hardened Push Rods
42lb InjectorS
Stock Bottom End
Vredestein Tires
Hawks Brake Pads
SJM ABS delete
MTI Lid
BMR Adjustable LCA
Arizen Seats
Electric Water pump
Underdrive pulleys
Wideband in car
Qa1 Front struts
UMI Drag Sway Bar
Rear seat delete
Big 3 wire upgrade
mikeygold@yahoo.com
