zddp additive question
hotairgnx548
hotairgnx548
anyone use the zddp additive in a roller cam engine? What did it do help or harm? Any coments? Thanks See ya John
It'll knock a few ounces out of your wallet. Those weight savings aren't worth it though.
I use it in all Buick engines, flat tappet and roller. :)
A hydraulic roller has about twice the spring pressures vs. flat tappet, the very small roller bearing in the lifters and rockers are subjected to extreme loads as most owners install them along with other items for more HP which also means higher RPM's.
Small price to pay for good protection, especially in a high performance engine.
If you use a performance oil like Brad Penn or Joe Gibbs, not needed there.
But our turbos push lots of contaminants into the crankcase/oil, so I prefer to use a less expensive oil with ZDDP Plus, since it is more cost effective when the oil is changed often like it should.
In the long run, less expensive clean oil is much better than premium dirty oil! :)
I agree... I run regular non synth oil with a bottle of Z. I change so often it doesn't make any sense to run a synth oil
