Just for now do a pass with lower boost and see if things smooth out, if not it could be rpm related.
OK, looking at the 2 logs for 15 psi log looks OK, the 20 psi log looks like your not making any power in the highlighted area, check your fuel system that it flows enough at high boost, it could be a spark blown out issue, bad coil pack or just plain the start of detonation, from the too hot plug , do one change at a time or you could be chasing your tail..
3.42 gear I believe. I will change the plugs to Autolite 133. Where should I start with the gap?
The PL log and his description above was in fact a bad coil. The car ran perfect until he hit 10psi boost. I'm really starting to think that's the issue. To be honest, I really dont like the LS2 coils because they cover up my nice valve covers. If it is a bad coil, it would be the second one in a year. Maybe I'll just get rid of them.
The autolite racing series have back cut electrodes, which maybe good for the track, but they wear out fast on the street, I had to stop using them right away. You have some iron heads holding the heat also, I would try a .028 gap if your planning to crank the boost.
