TurboTnZ06
Go on red!
- May 7, 2002
Thats huge! a ton less stress for roughly the same e.t that is a fantastic improvement.
The old combo at 17-18 psi only ran 11.8-12.0 at 113-115.
My GN1 exhaust ports are bigger than the stock header openings, so I'm probably leaving something on the table there for header flow.
I went to at least 35-40 over DLS stroker (my block was already 33 over from before), ported the lower stock intake, 70mm throttle body, 3 inch uppipe, wideband correction, 4 inch intake, but everything else related to air flow is the same. Spoolup is instantaneous on a 10 yr old journal turbo now. 0-25psi in .8 seconds leaving off the footbrake and bleeder style external wastegate control according to the log.
